跳转到主内容
Asus K53E-BBR3 Keyboard Replacement
你所需要的
  1. Asus K53E-BBR3 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Asus K53E-BBR3 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Asus K53E-BBR3 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: 步骤 2 中的图像 3,3
    • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
    • Insert the spudger into the indent near the "ESC" key.
    • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
  3. Asus K53E-BBR3 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Gently pull the ribbon cable to the right and out of its port.
结论
Liza Sousa
于10/17/16注册
355 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 792
