跳转到主内容
Asus K53E-BBR3 Hard Drive Replacement
你所需要的
  1. Asus K53E-BBR3 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Asus K53E-BBR3 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Asus K53E-BBR3 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Hard Drive Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Unscrew the four 5mm Phillips #1 screws.
    • Lift the hard drive out of the computer.
  5. Asus K53E-BBR3 Hard Drive Replacement: 步骤 5 中的图像 1,2 Asus K53E-BBR3 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Unscrew the screws on the hard drive case.
    • Two 3mm Phillips #1 screws are located on one edge of the case.
    • The last two 3mm #1 Phillips screws are located on the opposite side of the case.
    • After you unscrew all four screws, the metal cage will fall off, leaving you with the hard drive.
结论
Jacob O'Donnell
于10/17/16注册
323 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 1,779
