跳转到主内容
Asus K52JC Laptop Hard Drive Replacement
你所需要的
  1. Asus K52JC Laptop Hard Drive Replacement, Power off and return the device: 步骤 1 中的图像 1,1
    • First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
    • Next, remove the battery from the laptop.
    • In the picture, the battery is not installed.
  2. Asus K52JC Laptop Hard Drive Replacement, Remove the screws and open the cover: 步骤 2 中的图像 1,2 Asus K52JC Laptop Hard Drive Replacement, Remove the screws and open the cover: 步骤 2 中的图像 2,2
    • Next, remove the 4 Phillips screws from the service door cover (circled in red).
    • In this photo, the screws have already been removed.
  3. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from it's location: 步骤 3 中的图像 1,2 Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from it's location: 步骤 3 中的图像 2,2
    • Remove the 4 screws circled in red in the photo.
    • Once the screws are removed, slide the hard drive to the right, with the help of the tab.
  4. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: 步骤 4 中的图像 1,3 Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: 步骤 4 中的图像 2,3 Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: 步骤 4 中的图像 3,3
    • Remove the 4 screws located on the side of the support.
    • Then, remove the hard drive form its metallic support.
    • Finally, replace de hard drive with a new one or an SSD.
结论
To reassemble your device, follow these steps in reverse order.
2等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Brendan
于09/24/16注册
51,566 声望
创作了3篇指南
3条评论
why do you do this?
Carl Jefferson - 回复
You can do this to replace a faulty hard-drive or replace it by a SSD to get better performance. So I did this to replace mine by a new one and I wrote this guide for other people who search how to do it. As you can see, very easy to do.
Brendan -
Amazing tutorial, thanks :)
Jérémy Martin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 1,505
