简介
Speakers may eventually blow out. This guide will help you replace the speakers on the ASUS K50IJ when they stop working.
你所需要的
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
Using the PH1 screwdriver, remove the two .75 mm screws out of the speaker, located in the bottom right corner of the laptop.
即将完成!
结论
