跳转到主内容
Asus GL551JW-AH71 Wi-Fi Card Replacement
你所需要的
  1. Asus GL551JW-AH71 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Asus GL551JW-AH71 Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Asus GL551JW-AH71 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,2 Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the two 16mm screws securing the access panel to the laptop.
  5. Asus GL551JW-AH71 Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Gently remove the cover once the screws are removed.
  6. Asus GL551JW-AH71 Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Locate the Wi-Fi card and detach both coaxial cables that are connected to the card.
    • The pictures in this step do not show a Wi-Fi card. The location where the Wi-Fi card would be located is indicated by the red rectangle.
  7. Asus GL551JW-AH71 Wi-Fi Card Replacement: 步骤 7 中的图像 1,1
    • Grasp the Wi-Fi card gently and remove it carefully.
    • The pictures in this step do not show a Wi-Fi card, since it is missing from this particular device.
结论
2等其他人完成本指南。
William Kelley
于03/20/19注册
1,035 声望
创作了7篇指南
团队
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S8G3
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 902
