跳转到主内容
Asus GL551JW-AH71 Upper Assembly Replacement
你所需要的
  1. Asus GL551JW-AH71 Upper Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 2 中的图像 1,2 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 2 中的图像 2,2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 3 中的图像 1,2 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 3 中的图像 2,2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: 步骤 4 中的图像 1,2 Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: 步骤 4 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 5 中的图像 1,3 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 5 中的图像 2,3 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 5 中的图像 3,3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 6 中的图像 1,2 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 6 中的图像 2,2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: 步骤 7 中的图像 1,2 Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: 步骤 7 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 8 中的图像 1,2 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 9 中的图像 1,2 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 9 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 10 中的图像 1,1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 11 中的图像 1,3 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 11 中的图像 2,3 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 11 中的图像 3,3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 12 中的图像 1,3 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 12 中的图像 2,3 Asus GL551JW-AH71 Upper Assembly Replacement: 步骤 12 中的图像 3,3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
结论
另外一个人完成了本指南。
William Kelley
于03/20/19注册
1,035 声望
创作了7篇指南
团队
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S8G3
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 468
