跳转到主内容
Asus GL551JW-AH71 Display Assembly Replacement
你所需要的
  1. Asus GL551JW-AH71 Display Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 2 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 2 中的图像 2,2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 3 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: 步骤 4 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: 步骤 4 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 5 中的图像 1,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 5 中的图像 2,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 6 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 6 中的图像 2,2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: 步骤 7 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: 步骤 7 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 8 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 9 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 9 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 10 中的图像 1,1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 11 中的图像 1,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 11 中的图像 2,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 11 中的图像 3,3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 12 中的图像 1,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 12 中的图像 2,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 12 中的图像 3,3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
  13. Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: 步骤 13 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: 步骤 13 中的图像 2,2
    • Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
    • A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
  14. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 14 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 14 中的图像 2,2
    • Lift the display assembly up, separating it from the base of the device.
  15. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 15 中的图像 1,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 15 中的图像 2,3 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 15 中的图像 3,3
    • Using a plastic opening tool, separate the bezel from the screen.
    • Insert the tool and slide it right to left to release the bezel from the screen.
  16. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 16 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 16 中的图像 2,2
    • Remove the four screws using a Phillips #0 screwdriver.
  17. Asus GL551JW-AH71 Display Assembly Replacement: 步骤 17 中的图像 1,2 Asus GL551JW-AH71 Display Assembly Replacement: 步骤 17 中的图像 2,2
    • Grab the screen in the corners and lift up to remove it.
结论
3等其他人完成本指南。
Alec Pimentel
于03/21/19注册
258 声望
撰写一个指南
团队
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 的会员
UMASSD-BAILEY-S19S8G3
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 812
