跳转到主内容
Asus G75VW-BHI7N07 Trackpad Buttons Replacement
你所需要的
  1. Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 步骤 1 中的图像 1,3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 步骤 1 中的图像 2,3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 步骤 1 中的图像 3,3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 2 中的图像 1,3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 2 中的图像 2,3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 2 中的图像 3,3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 3 中的图像 1,2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 3 中的图像 2,2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 4 中的图像 1,2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 4 中的图像 2,2
    • Take off the henge cover using the opening tool.
    • Remove the 2 black outside edge (9 mm) screws with the J0 Phillips screwdriver.
  5. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 5 中的图像 1,3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 5 中的图像 2,3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 5 中的图像 3,3
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands.
    • Remove all electrical connections using your hands.
  6. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 6 中的图像 1,2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 步骤 6 中的图像 2,2
    • Take the 2 (3 mm) screws out of the trackpad using the PH1 Phillips screwdriver.
    • Remove the trackpad buttons using your hands.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,295
