跳转到主内容
Asus G75VW-BHI7N07 Audio Jack Replacement
你所需要的
  1. Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: 步骤 1 中的图像 1,3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: 步骤 1 中的图像 2,3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: 步骤 1 中的图像 3,3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 2 中的图像 1,3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 2 中的图像 2,3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 2 中的图像 3,3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 3 中的图像 1,2 Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 3 中的图像 2,2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 4 中的图像 1,2 Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 4 中的图像 2,2
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands to get to the laptop's internal systems.
  5. Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 5 中的图像 1,3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 5 中的图像 2,3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 步骤 5 中的图像 3,3
    • Take out 1 (5mm) screw, using the J0 Phillips head screwdriver.
    • Use the opening tool to remove the audio-electrical board.
    • Lift out with your hands.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 11
总计 650
