跳转到主内容
Asus G750JW-BBI7N05 RAM Replacement
你所需要的
  1. Asus G750JW-BBI7N05 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 RAM Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 RAM Replacement, RAM: 步骤 4 中的图像 1,2 Asus G750JW-BBI7N05 RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Lift up the rubber stopper on the backplate to expose one Phillips screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the backplate from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 RAM Replacement: 步骤 5 中的图像 1,1
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 RAM Replacement: 步骤 6 中的图像 1,2 Asus G750JW-BBI7N05 RAM Replacement: 步骤 6 中的图像 2,2
    • During the recycling process, this laptop lost some of its parts. In this step, its top two RAM modules are missing.
    • Remove each RAM module one at a time by sliding them downward out of their slots.
结论
另外一个人完成了本指南。
一条评论
What about how to remove the other two internal RAM Modules?
Latiron London - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 761
