跳转到主内容
Asus G750JW-BBI7N05 Display Replacement
你所需要的
  1. Asus G750JW-BBI7N05 Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Display Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Display Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Display Replacement, Display: 步骤 4 中的图像 1,1
    • Place your laptop in the upright and open position.
  5. Asus G750JW-BBI7N05 Display Replacement: 步骤 5 中的图像 1,1
    • Remove the four 4mm Phillips #00 screws from the four corners of the display.
  6. Asus G750JW-BBI7N05 Display Replacement: 步骤 6 中的图像 1,1
    • Gently pry the front bezel away from the screen and back bezel with an opening tool.
    • The bezel is the outside plastic frame surrounding the screen.
    • You will feel and hear the bezel "unsnap" as you move the pry tool around the entire display.
  7. Asus G750JW-BBI7N05 Display Replacement: 步骤 7 中的图像 1,1
    • As you work, be mindful of other components that surround the screen, like the WiFi antenna, Bluetooth, webcam, and microphone.
    • Remove the six 6mm Phillips #00 screws across the top of the screen and the four 6mm Phillips #00 screws at the bottom of the screen.
  8. Asus G750JW-BBI7N05 Display Replacement: 步骤 8 中的图像 1,1
    • With the screws removed, the metal bracket surrounding the screen will feel loose.
    • Remove the top bracket by pulling upwards on the tabs.
  9. Asus G750JW-BBI7N05 Display Replacement: 步骤 9 中的图像 1,1
    • Remove the four 3mm Phillips #00 screws from the sides of the screen.
  10. Asus G750JW-BBI7N05 Display Replacement: 步骤 10 中的图像 1,1
    • With the screen free, tilt it gently forward to reveal the display data cable.
    • Unplug the display data cable by peeling off the clear sticker covering its connector, then pulling this connector out of its socket.
    • Make sure to only peel off the sticker that covers the display data cable connector.
  11. Asus G750JW-BBI7N05 Display Replacement: 步骤 11 中的图像 1,2 Asus G750JW-BBI7N05 Display Replacement: 步骤 11 中的图像 2,2
    • Remove the two side brackets from the sides of the screen by removing the six 3mm Phillips #00 screws attaching it. There are three screws on either side of the screen.
结论
5等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 2,204
