Begin by removing the six square rubber pads around the edge of the frame. These cover the screws to remove the outer frame. They can be taken out by hand or with a pair of tweezers.
The squares are attached by a light adhesive which may need to be replaced if it wears off due to constant removal
Next, remove the six 6mm Phillip #0 screws from the frame using a Phillips #0 screwdriver.
The last step is to remove eight 3mm Phillip #0 screws from both side brackets of the screen itself using a Phillips #0 screwdriver. There are four screws on each side.
