跳转到主内容
Asus G74SX-BBK7 RAM Replacement
你所需要的
  1. Asus G74SX-BBK7 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 RAM Replacement: 步骤 2 中的图像 1,3 Asus G74SX-BBK7 RAM Replacement: 步骤 2 中的图像 2,3 Asus G74SX-BBK7 RAM Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Locate the RAM near the center of the computer.
    • Push gently on the metal pins that are on both sides of the RAM sticks.
    • Before touching the RAM, discharge any built-up static by touching a metal surface or wearing an antistatic wrist strap.
  3. Asus G74SX-BBK7 RAM Replacement: 步骤 3 中的图像 1,1
    • When you push on the pins, the RAM will pop up. Gently remove it from its socket.
    • Repeat the third and fourth step for the second stick of RAM, located behind the first stick.
结论
2等其他人完成本指南。
Josiah Avery
于04/15/15注册
131 声望
撰写一个指南
团队
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G10
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 14
总计 710
