简介
Does your computer frequently crash, freeze, reboot, or show the black screen of death? If so, here is the guide to simply remove the RAM chips, buy new ones and reinstall them. All you need is the standard Phillips #0 screwdriver in order to remove the screws.
你所需要的
Begin by turning the device off and removing any power cords. Disassembling the device while it is under power may result in electric shock and potential damage to the device.
Flip the device upside down and rotate it so the battery port is facing away from you. Remove the two 5.5 mm Phillips #0 screws on the smaller back panel.
Lift the keyboard partially away from from the device. A ribbon cable will still be connecting the keyboard to the device.
Using the plastic opening tool, slide the small clips on either side of the ribbon cable to the left. The ribbon cable should now be released.
Gently pull the ribbon cable and set the keyboard aside.
Remove four 5.5 mm Phillips #0 screws in the area where the keyboard used to be.
Insert the opener tool into the seam between the top and bottom panels. Using the plastic opening tool, gently pry the top panel upwards until it pops free. Repeat this process along the entire perimeter of the panel.
When the panel is free, grab the edge of the panel that is closest to you and pull it toward you.
