跳转到主内容
Asus G73JW-XT1 Optical Drive Replacement
你所需要的
  1. Asus G73JW-XT1  Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over so the battery port is easy to access.
  2. Asus G73JW-XT1  Optical Drive Replacement: 步骤 2 中的图像 1,2 Asus G73JW-XT1  Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the left slider to the left so that it locks in place.
    • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
  3. Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,2 Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 2,2
    • Turn the device off and remove any power cords. Dissassembling the device while it is under power may result in electric shock and potential damage to the device.
    • Rotate the device so the battery port is facing away.
    • Remove two 5.5 mm Phillips #0 screws on the back panel.
  4. Asus G73JW-XT1  Optical Drive Replacement: 步骤 4 中的图像 1,3 Asus G73JW-XT1  Optical Drive Replacement: 步骤 4 中的图像 2,3 Asus G73JW-XT1  Optical Drive Replacement: 步骤 4 中的图像 3,3
    • Insert the opener tool into the small groove at the edge of the panel.
    • Using opener tool, gently pry the back panel upward until it lifts free from the device.
    • Gently lift the panel off with your fingers.
  5. Asus G73JW-XT1  Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Remove one 5.5 mm Phillips #0 screw directly to the right of the RAM cards.
  6. Asus G73JW-XT1  Optical Drive Replacement: 步骤 6 中的图像 1,2 Asus G73JW-XT1  Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Insert the plastic opening tool in the gap between the motherboard and the back panel, directly to the right of the RAM cards.
    • Gently push the optical drive outwards. This should require very little pressure.
    • Grab the loose optical drive with your fingers and pull it free.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 298
