跳转到主内容
Asus G73JH-RBBX05 Fan Replacement
你所需要的
  1. Asus G73JH-RBBX05 Fan Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus G73JH-RBBX05 Fan Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
  2. Asus G73JH-RBBX05 Fan Replacement: 步骤 2 中的图像 1,3 Asus G73JH-RBBX05 Fan Replacement: 步骤 2 中的图像 2,3 Asus G73JH-RBBX05 Fan Replacement: 步骤 2 中的图像 3,3
    • Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
    • In order to remove these cables, push forward the black retention clips and pull out the cables.
  3. Asus G73JH-RBBX05 Fan Replacement, Fan: 步骤 3 中的图像 1,1
    • Remove the 4mm screws located under the keyboard with the PH0 screwdriver.
  4. Asus G73JH-RBBX05 Fan Replacement: 步骤 4 中的图像 1,2 Asus G73JH-RBBX05 Fan Replacement: 步骤 4 中的图像 2,2
    • Using a PH0 screwdriver, remove the two, 4mm screws .
    • Using either your finger or a plastic opening tool, remove the back panel.
  5. Asus G73JH-RBBX05 Fan Replacement: 步骤 5 中的图像 1,1
    • Using the PH0 screwdriver, remove the nine, 4mm screws on the bottom of the laptop.
    • You must remove the two, 4mm screws located under the battery. Remove the battery by following these steps: Asus G73JH-RBBX05 Battery Replacement
  6. Asus G73JH-RBBX05 Fan Replacement: 步骤 6 中的图像 1,1
    • Using a metal spudger, remove the back cover of the laptop.
    • Apply constant force in order to unhinged the panel.
  7. Asus G73JH-RBBX05 Fan Replacement: 步骤 7 中的图像 1,2 Asus G73JH-RBBX05 Fan Replacement: 步骤 7 中的图像 2,2
    • Remove the four, 4mm screws located on both of the hinges using the PH0 screwdriver and flip open the device.
    • Make sure you do this step for both the left and right hinges.
  8. Asus G73JH-RBBX05 Fan Replacement: 步骤 8 中的图像 1,2 Asus G73JH-RBBX05 Fan Replacement: 步骤 8 中的图像 2,2
    • Using a metal pry tool, remove the base cover
    • Once the cover is completely unhinged, don't forget to detach the strips connected to the motherboard.
  9. Asus G73JH-RBBX05 Fan Replacement: 步骤 9 中的图像 1,3 Asus G73JH-RBBX05 Fan Replacement: 步骤 9 中的图像 2,3 Asus G73JH-RBBX05 Fan Replacement: 步骤 9 中的图像 3,3
    • Locate the fan and remove the three 2mm screws with the PH0 screwdriver.
    • Before removing the fan, disconnect the cable.
结论
3等其他人完成本指南。
Trevor Sprosty
于01/23/17注册
409 声望
创作了3篇指南
团队
Cal Poly, Team 22-11, Maness Winter 2017 Cal Poly, Team 22-11, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G11
3 名成员
创作了5篇指南
一条评论
Some steps missing, regarding screws to remove: 1 screw that holds optical drive; once that is removed, 2 screws in the drive compartment; 2 screws in the battery compartment; 3 screws from the bottom of the motherboard.
Byron Canfield - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,595
