跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
This guide requires a basic toolkit and deals with the battery of a laptop. Replacing your battery could be a good solution if you are running into problems with a shortened battery life or you have a higher quality replacement battery ready.
  1. Attach the clip of your anti-static wrist strap to the case of the laptop.  This prevents any accidents that could fry the motherboard. Remove the four 7.0mm Philips #0 screws around the battery.
    • Attach the clip of your anti-static wrist strap to the case of the laptop. This prevents any accidents that could fry the motherboard.
    • Remove the four 7.0mm Philips #0 screws around the battery.
  2. Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the  battery away from the motherboard and remove the battery.
    • Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the battery away from the motherboard and remove the battery.
结论
Bruce Baker
于2017年02月01日注册
301 信誉积分
创作了3篇指南
团队
UW Tacoma, Team 2-1, Rose Winter 2017 UW Tacoma, Team 2-1, Rose Winter 2017 的会员
UWT-ROSE-W17S2G1
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 8
过去的30天: 35
总计 1,620
