跳转到主内容
Asus F6A-X2 RAM Replacement
你所需要的
  1. Asus F6A-X2 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
  2. Asus F6A-X2 RAM Replacement, Back Access Panel: 步骤 2 中的图像 1,2 Asus F6A-X2 RAM Replacement, Back Access Panel: 步骤 2 中的图像 2,2
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  3. Asus F6A-X2 RAM Replacement: 步骤 3 中的图像 1,3 Asus F6A-X2 RAM Replacement: 步骤 3 中的图像 2,3 Asus F6A-X2 RAM Replacement: 步骤 3 中的图像 3,3
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
  4. Asus F6A-X2 RAM Replacement, RAM: 步骤 4 中的图像 1,2 Asus F6A-X2 RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Make sure to check the RAM specifications on the device page.
    • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
    • You will hear a pop and visibly see the RAM move upwards.
    • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
  5. Asus F6A-X2 RAM Replacement: 步骤 5 中的图像 1,2 Asus F6A-X2 RAM Replacement: 步骤 5 中的图像 2,2
    • Repeat the process from the previous step to remove the bottom RAM.
结论
另外一个人完成了本指南。
Jonathan
于04/24/14注册
1,174 声望
创作了11篇指南
团队
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G56
4 名成员
创作了12篇指南
一条评论
Tutorel simple et très clair.
Merci
alainbadinier - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 568
