你所需要的
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
Lay the laptop right side up.
Rotate laptop 90 degrees towards you, so the empty battery compartment is visible.
With a pair of tweezers, grab on to the white connector at the bottom of the screen. Gently, but firmly, pull the connector to the right to to remove it.
Repeat this process with the white connector attached to the webcam above the screen.
