跳转到主内容
Asus F6A-X2 Hard Drive Replacement
你所需要的
  1. Asus F6A-X2 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
  2. Asus F6A-X2 Hard Drive Replacement, Back Access Panel: 步骤 2 中的图像 1,2 Asus F6A-X2 Hard Drive Replacement, Back Access Panel: 步骤 2 中的图像 2,2
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  3. Asus F6A-X2 Hard Drive Replacement: 步骤 3 中的图像 1,3 Asus F6A-X2 Hard Drive Replacement: 步骤 3 中的图像 2,3 Asus F6A-X2 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
  4. Asus F6A-X2 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Asus F6A-X2 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Rotate the laptop 90 degrees towards you so that you are looking at the empty battery compartment.
  5. Asus F6A-X2 Hard Drive Replacement: 步骤 5 中的图像 1,2 Asus F6A-X2 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the 2.0 mm Phillips #3 screw located beneath the battery compartment.
  6. Asus F6A-X2 Hard Drive Replacement: 步骤 6 中的图像 1,3 Asus F6A-X2 Hard Drive Replacement: 步骤 6 中的图像 2,3 Asus F6A-X2 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Lay the laptop flat on its back.
    • Gently pull left on the black tab, located on the left side of the hard drive, until it pops out.
    • Slowly lift the tab up and pull the hard drive out of the laptop.
结论
另外一个人完成了本指南。
Jonathan
于04/24/14注册
1,174 声望
创作了11篇指南
团队
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G56
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 866
