跳转到主内容
Asus F6A-X2 Front Bezel Replacement
你所需要的
  1. Asus F6A-X2 Front Bezel Replacement, Front Bezel: 步骤 1 中的图像 1,2 Asus F6A-X2 Front Bezel Replacement, Front Bezel: 步骤 1 中的图像 2,2
    • Lay the laptop right side up.
    • Rotate laptop 90 degrees towards you, so the empty battery compartment is visible.
  2. Asus F6A-X2 Front Bezel Replacement: 步骤 2 中的图像 1,2 Asus F6A-X2 Front Bezel Replacement: 步骤 2 中的图像 2,2
    • Insert a finger nail, or the flat end of the spudger, into the slot between the laptop base and the hinge guard on the right side. Gently pull the guard towards you until the guard pops off.
    • Repeat this process for the other guard.
  3. Asus F6A-X2 Front Bezel Replacement: 步骤 3 中的图像 1,2 Asus F6A-X2 Front Bezel Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Once the hinge guards are removed, lay the laptop flat on its bottom. Then, lift open the laptop screen as if you were about to use it.
    • With a pair of tweezers, peel off the six rubber cushions from the bezel located around the perimeter of the screen.
  4. Asus F6A-X2 Front Bezel Replacement: 步骤 4 中的图像 1,2 Asus F6A-X2 Front Bezel Replacement: 步骤 4 中的图像 2,2
    • Remove the six 2.0 mm Phillips #1 screws from the perimeter of the bezel.
  5. Asus F6A-X2 Front Bezel Replacement: 步骤 5 中的图像 1,2 Asus F6A-X2 Front Bezel Replacement: 步骤 5 中的图像 2,2
    • Insert a finger nail, or the flat end of a spudger, into the slit between the bezel and the back cover of the laptop.
    • Gently pry the bezel towards you to remove it from the back panel of the laptop.
    • Hearing a cracking noise is normal. The bezel is not damaged in this process.
    • Continue to pry around the perimeter of the laptop until the entire bezel has been removed.
结论
Jonathan
于04/24/14注册
1,174 声望
创作了11篇指南
团队
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G56
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 488
