With the panel removed, The single upgradable RAM slot is easily accessible.
If RAM is already installed, it can be removed by gently pulling the retainers sideways away from the RAM to release it.
To install RAM, slide the DIMM into the socket at an angle of approximately 20 degrees from flat. Make sure the notch in the RAM module aligns with the notch in the socket. Gently push down on the RAM module until the retainers click into place.
