跳转到主内容
Asus F555LA-AB31 RAM Replacement
你所需要的
  1. Asus F555LA-AB31 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Remove the Phillips #0 screw holding the RAM access panel in place.
    • Gently lift up on the edge of the panel to remove it.
  2. Asus F555LA-AB31 RAM Replacement: 步骤 2 中的图像 1,1
    • With the panel removed, The single upgradable RAM slot is easily accessible.
    • If RAM is already installed, it can be removed by gently pulling the retainers sideways away from the RAM to release it.
    • To install RAM, slide the DIMM into the socket at an angle of approximately 20 degrees from flat. Make sure the notch in the RAM module aligns with the notch in the socket. Gently push down on the RAM module until the retainers click into place.
结论
To reassemble your device, reinstall the access panel by following these instructions in reverse order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 30
总计 873
