跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Open the laptop. Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device. Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • Open the laptop.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Fold the faceplate upwards towards the screen to fully expose the inside of the laptop. Remove the CD Drive by unscrewing the single Phillips #0 screw and sliding the drive away from the motherboard.
    • Fold the faceplate upwards towards the screen to fully expose the inside of the laptop.
    • Remove the CD Drive by unscrewing the single Phillips #0 screw and sliding the drive away from the motherboard.
  4. Remove ten 18mm Phillips #0 screws from the backside of the device.
  5. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  6. Carefully fold the device open. Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device. Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • Carefully fold the device open.
  7. Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device. Unscrew the four 4mm Phillips #0 screws holding down the hard drive. Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  8. Disconnect the ZIF connector and lift the hard drive out of the space.
    • Disconnect the ZIF connector and lift the hard drive out of the space.
  9. Remove the 4mm Phillips #0 screws. Remove the 4mm Phillips #0 screws.
    • Remove the 4mm Phillips #0 screws.
  10. Lift up battery and remove. Lift up battery and remove.
    • Lift up battery and remove.
  11. Disconnect the two wires connected to the network card.
    • Disconnect the two wires connected to the network card.
  12. Remove the seven Phillips #0 screws holding the motherboard down. Lift the motherboard upwards, folding it towards the laptop chassis. Unscrew the Phillips #0 screw holding down the network card, and slide it out.
    • Remove the seven Phillips #0 screws holding the motherboard down.
    • Lift the motherboard upwards, folding it towards the laptop chassis.
    • Unscrew the Phillips #0 screw holding down the network card, and slide it out.
结论
David Burns
于2019年04月04日注册
85 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 7
总计 198
