跳转到主内容
Asus F555LA-AB31 Hard Drive Replacement
你所需要的
  1. Asus F555LA-AB31 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Hard Drive Replacement: 步骤 2 中的图像 1,3 Asus F555LA-AB31 Hard Drive Replacement: 步骤 2 中的图像 2,3 Asus F555LA-AB31 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Hard Drive Replacement: 步骤 3 中的图像 1,3 Asus F555LA-AB31 Hard Drive Replacement: 步骤 3 中的图像 2,3 Asus F555LA-AB31 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  4. Asus F555LA-AB31 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Disconnect the ZIF connector and lift the hard drive out of the space.
结论
另外一个人完成了本指南。
一条评论
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
Jeb - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 25
总计 1,801
