跳转到主内容
Asus F554LA-WS52 Keyboard Replacement
你所需要的
  1. Asus F554LA-WS52 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus F554LA-WS52 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Keyboard Replacement: 步骤 2 中的图像 1,3 Asus F554LA-WS52 Keyboard Replacement: 步骤 2 中的图像 2,3 Asus F554LA-WS52 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Flip the notebook back over.
    • Gently lift and remove the keyboard with a plastic opening tool.
  3. Asus F554LA-WS52 Keyboard Replacement: 步骤 3 中的图像 1,1
    • (Not pictured) Remove the three cables attached to the keyboard and one from the touch-pad.
    • (Not pictured) With the plastic opening tool, pry off the metal separation plate from the keyboard.
    • (Not pictured) With the plastic opening tool, gently pry the keyboard from its position and replace.
结论
Aaron Ratliff
于10/09/18注册
527 声望
创作了4篇指南
团队
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 的会员
USFT-LEAHY-F18S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 332
