跳转到主内容
Asus F554LA-WS52 Fan Replacement
你所需要的
  1. Asus F554LA-WS52 Fan Replacement, Disc Drive: 步骤 1 中的图像 1,2 Asus F554LA-WS52 Fan Replacement, Disc Drive: 步骤 1 中的图像 2,2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Fan Replacement: 步骤 2 中的图像 1,3 Asus F554LA-WS52 Fan Replacement: 步骤 2 中的图像 2,3 Asus F554LA-WS52 Fan Replacement: 步骤 2 中的图像 3,3
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Fan Replacement: 步骤 3 中的图像 1,2 Asus F554LA-WS52 Fan Replacement: 步骤 3 中的图像 2,2
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Fan Replacement: 步骤 4 中的图像 1,2 Asus F554LA-WS52 Fan Replacement: 步骤 4 中的图像 2,2
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Fan Replacement: 步骤 5 中的图像 1,3 Asus F554LA-WS52 Fan Replacement: 步骤 5 中的图像 2,3 Asus F554LA-WS52 Fan Replacement: 步骤 5 中的图像 3,3
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
  6. Asus F554LA-WS52 Fan Replacement, Fan: 步骤 6 中的图像 1,1
    • Remove the eight 5.7mm screws using the Phillips #0 Screwdriver.
  7. Asus F554LA-WS52 Fan Replacement: 步骤 7 中的图像 1,2 Asus F554LA-WS52 Fan Replacement: 步骤 7 中的图像 2,2
    • Unscrew and remove the two 5.7mm screws from the fan with the Phillips #0 Screwdriver.
    • Gently lift the motherboard and fan to access the components underneath.
  8. Asus F554LA-WS52 Fan Replacement: 步骤 8 中的图像 1,1
    • Unscrew and remove the four 0.01mm screws using the Phillips #0 Screwdriver from the heatsink.
  9. Asus F554LA-WS52 Fan Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently unplug power strip with fingers or tweezers to remove fan.
    • Gently pull fan from heatsink.
    • Replace fan.
结论
Aaron Ratliff
于10/09/18注册
527 声望
创作了4篇指南
团队
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 的会员
USFT-LEAHY-F18S1G2
4 名成员
创作了6篇指南
一条评论
It would be nice to identify which screws are long on the case removal to make reassembly easier.
Also it is easier if the laptop is open to unsnap the cover so the screen doesn’t block it.
Roland - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 611
