跳转到主内容
Asus F554LA-WS52 Disc Drive
你所需要的
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: 步骤 1 中的图像 1,2 Asus F554LA-WS52 Disc Drive, Disc Drive: 步骤 1 中的图像 2,2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: 步骤 2 中的图像 1,3 Asus F554LA-WS52 Disc Drive: 步骤 2 中的图像 2,3 Asus F554LA-WS52 Disc Drive: 步骤 2 中的图像 3,3
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: 步骤 3 中的图像 1,2 Asus F554LA-WS52 Disc Drive: 步骤 3 中的图像 2,2
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: 步骤 4 中的图像 1,2 Asus F554LA-WS52 Disc Drive: 步骤 4 中的图像 2,2
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: 步骤 5 中的图像 1,3 Asus F554LA-WS52 Disc Drive: 步骤 5 中的图像 2,3 Asus F554LA-WS52 Disc Drive: 步骤 5 中的图像 3,3
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
结论
2等其他人完成本指南。
Aaron Ratliff
于10/09/18注册
527 声望
创作了4篇指南
团队
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 的会员
USFT-LEAHY-F18S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 559
