跳转到主内容
Asus EeeBook X205TA Speakers Replacement
你所需要的
  1. Asus EeeBook X205TA Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Asus EeeBook X205TA Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: 步骤 3 中的图像 1,2 Asus EeeBook X205TA Speakers Replacement: 步骤 3 中的图像 2,2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: 步骤 6 中的图像 1,1
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: 步骤 7 中的图像 1,1
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: 步骤 8 中的图像 1,1
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: 步骤 9 中的图像 1,1
    • Pry the left speaker gently with the plastic opening tool.
结论
另外一个人完成了本指南。
William Riggins
于03/21/17注册
312 声望
创作了2篇指南
团队
IUPUI, Team S3-G4, Baechle Spring 2017 IUPUI, Team S3-G4, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S3G4
4 名成员
创作了6篇指南
2条评论
Thank you very much for this detailed and helpful tutorial.
andrew - 回复
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 890
