跳转到主内容
Asus EeeBook X205TA Screen Assembly Replacement
你所需要的
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: 步骤 1 中的图像 1,2 Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: 步骤 1 中的图像 2,2
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: 步骤 3 中的图像 1,3 Asus EeeBook X205TA Screen Assembly Replacement: 步骤 3 中的图像 2,3 Asus EeeBook X205TA Screen Assembly Replacement: 步骤 3 中的图像 3,3
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: 步骤 4 中的图像 1,1
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G2
3 名成员
创作了10篇指南
一条评论
What's that small black screen hanging out from the laptop
Tayler Grant - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,398
