跳转到主内容
Asus EeeBook X205TA Motherboard Replacement
你所需要的
  1. Asus EeeBook X205TA Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Asus EeeBook X205TA Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Unscrew all 10 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Motherboard Replacement: 步骤 3 中的图像 1,2 Asus EeeBook X205TA Motherboard Replacement: 步骤 3 中的图像 2,2
    • Unscrew all seven screws around the outer edge of the motherboard using 2mm Phillips Screwdriver.
  4. Asus EeeBook X205TA Motherboard Replacement: 步骤 4 中的图像 1,2 Asus EeeBook X205TA Motherboard Replacement: 步骤 4 中的图像 2,2
    • Unplug the No-Fuss Ribbon battery, screen, and speakers from the motherboard.
    • Carefully remove the ZIF screen connector.
结论
10等其他人完成本指南。
Shahir Makary
于10/06/16注册
294 声望
撰写一个指南
团队
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G2
3 名成员
创作了10篇指南
3条评论
Very clear and precise instructions. Thanks
wdkandler - 回复
Here is a more detailed view of all the cables that have to be unplugged before the motherboard can be extracted: https://ibb.co/jcgwUQ
Also, be aware that, even after all screws and cables are removed, it will still require a little bit of force to remove the motherboard, due to the thermal adhesive on the CPU and GPU. Do not be afraid to pull the motherboard! As long as you followed the instructions and disconnected all the EIGHT cables and SEVEN screws, you are not going to damage anything, it’s just thermal tape!
Sebastian Swirski - 回复
I guess because if the spill damage, the motherboard stop my keyboard from working and the usual from
Tayler Grant - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 39
总计 6,876
