跳转到主内容
Asus EeeBook X205TA Battery Replacement
你所需要的
  1. Asus EeeBook X205TA Battery Replacement, Battery: 步骤 1 中的图像 1,2 Asus EeeBook X205TA Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: 步骤 3 中的图像 1,2 Asus EeeBook X205TA Battery Replacement: 步骤 3 中的图像 2,2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the battery out of the laptop.
结论
Follow the guide in reverse order to reassemble the device.
8等其他人完成本指南。
团队
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G2
3 名成员
创作了10篇指南
11条评论
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - 回复
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - 回复
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 70
总计 14,054
