跳转到主内容
Asus EeeBook X205TA USB Port Replacement
你所需要的
  1. Asus EeeBook X205TA  USB Port Replacement, USB Port: 步骤 1 中的图像 1,2 Asus EeeBook X205TA  USB Port Replacement, USB Port: 步骤 1 中的图像 2,2
    • Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA  USB Port Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA  USB Port Replacement: 步骤 3 中的图像 1,2 Asus EeeBook X205TA  USB Port Replacement: 步骤 3 中的图像 2,2
    • The USB ports are located on the strip that looks like the motherboard on the left side of the laptop next to the battery.
    • Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
    • Unplug the battery ZIF connector from the USB ports.
  4. Asus EeeBook X205TA  USB Port Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the USB ports from the laptop.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 2,476
