跳转到主内容
Asus Eee PC T101MT Wireless Network Interface Card Replacement
你所需要的
  1. Asus Eee PC T101MT Wireless Network Interface Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, make sure your device is powered off and not connected to the power supply.
    • Turn the tablet over and position it so it matches the picture.
  2. Asus Eee PC T101MT Wireless Network Interface Card Replacement: 步骤 2 中的图像 1,1
    • Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
  3. Asus Eee PC T101MT Wireless Network Interface Card Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
  4. Asus Eee PC T101MT Wireless Network Interface Card Replacement: 步骤 4 中的图像 1,1
    • Lift the battery out of the device.
  5. Asus Eee PC T101MT Wireless Network Interface Card Replacement, Keyboard: 步骤 5 中的图像 1,3 Asus Eee PC T101MT Wireless Network Interface Card Replacement, Keyboard: 步骤 5 中的图像 2,3 Asus Eee PC T101MT Wireless Network Interface Card Replacement, Keyboard: 步骤 5 中的图像 3,3
    • Turn the tablet over and open it up. Insert a nylon spudger into the slots above F1, F6, F10 to pry up the keyboard.
  6. Asus Eee PC T101MT Wireless Network Interface Card Replacement: 步骤 6 中的图像 1,1
    • Once you have the keyboard out, use the nylon spudger to remove the connection. You can now replace the keyboard.
  7. Asus Eee PC T101MT Wireless Network Interface Card Replacement, Wireless Network Interface Card: 步骤 7 中的图像 1,1
    • Locate the wireless NIC (network interface card).
  8. Asus Eee PC T101MT Wireless Network Interface Card Replacement: 步骤 8 中的图像 1,2 Asus Eee PC T101MT Wireless Network Interface Card Replacement: 步骤 8 中的图像 2,2
    • Use a nylon spudger to lift the wireless antenna from the NIC and remove the screws.
  9. Asus Eee PC T101MT Wireless Network Interface Card Replacement: 步骤 9 中的图像 1,1
    • Remove and replace the wireless card.
结论
团队
Gateway, Team 1-1, Kuhn Fall 2015 Gateway, Team 1-1, Kuhn Fall 2015 的会员
GCC-KUHN-F15S1G1
1 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 19
总计 649
