跳转到主内容
Asus Eee PC T101MT RAM Replacement
你所需要的
  1. Asus Eee PC T101MT RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, make sure your device is powered off and not connected to the power supply.
    • Turn the tablet over and position it so it matches the picture.
  2. Asus Eee PC T101MT RAM Replacement: 步骤 2 中的图像 1,1
    • Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
  3. Asus Eee PC T101MT RAM Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
  4. Asus Eee PC T101MT RAM Replacement: 步骤 4 中的图像 1,1
    • Lift the battery out of the device.
  5. Asus Eee PC T101MT RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • Locate the compartment where the RAM is stored.
  6. Asus Eee PC T101MT RAM Replacement: 步骤 6 中的图像 1,2 Asus Eee PC T101MT RAM Replacement: 步骤 6 中的图像 2,2
    • Grab a drive adapter and a PH0 phillips head bit and use the screwdriver to remove the 5mm screw from the cover of the compartment.
  7. Asus Eee PC T101MT RAM Replacement: 步骤 7 中的图像 1,2 Asus Eee PC T101MT RAM Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to remove the cover.
  8. Asus Eee PC T101MT RAM Replacement: 步骤 8 中的图像 1,3 Asus Eee PC T101MT RAM Replacement: 步骤 8 中的图像 2,3 Asus Eee PC T101MT RAM Replacement: 步骤 8 中的图像 3,3
    • In order to release the RAM module, you will need to move the metal tabs on both sides at the same time. This can be accomplished by using plastic opening tools or your fingers.
  9. Asus Eee PC T101MT RAM Replacement: 步骤 9 中的图像 1,2 Asus Eee PC T101MT RAM Replacement: 步骤 9 中的图像 2,2
    • Once you move the tabs, the RAM module will pop up and you can remove it with your fingers so you can put in a replacement.
结论
2等其他人完成本指南。
团队
Gateway, Team 1-1, Kuhn Fall 2015 Gateway, Team 1-1, Kuhn Fall 2015 的会员
GCC-KUHN-F15S1G1
1 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 518
