跳转到主内容
  1. Slide the battery's locking tabs from the locked position to unlocked positions. The right tab is unlocked when a red dot is showing. The left tab will have to be held in the unlocked position in order to release the battery.
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Slide the battery out while holding the left locking tab in the unlocked position.
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed. Identify the three metal tabs holding down the laptop's keyboard.
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible. Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. Remove the keyboard by lifting upwards.
    • Remove the keyboard by lifting upwards.
  7. Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop. Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
  8. Remove the six 4.76 mm Phillips #0 screws on the back of the laptop. Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
  9. Flip the laptop back over and identify the touchpad ribbon. Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger. Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
  10. Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
  11. Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
  12. Caution:  To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage. Remove the laptop cover. Remove the laptop cover.
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
  13. Flip the top cover over and identify the touchpad back plate. Flip the top cover over and identify the touchpad back plate.
    • Flip the top cover over and identify the touchpad back plate.
  14. Identify the conductive foil. Caution: Do not completely remove conductive foil. Fold back the conductive foil from the touchpad back plate using a spudger.
    • Identify the conductive foil.
    • Caution: Do not completely remove conductive foil.
    • Fold back the conductive foil from the touchpad back plate using a spudger.
  15. Remove the two 4.76mm Phillips #0 screws securing the touchpad back plate. Remove the two 4.76mm Phillips #0 screws securing the touchpad back plate.
    • Remove the two 4.76mm Phillips #0 screws securing the touchpad back plate.
  16. Remove the yellow tape holding the touchpad's ribbon connector with a spudger.
    • Remove the yellow tape holding the touchpad's ribbon connector with a spudger.
  17. Use a spudger to lift the front edge of the touchpad back plate. Gently grasp the edges of the back plate and pull towards you to remove. Gently grasp the edges of the back plate and pull towards you to remove.
    • Use a spudger to lift the front edge of the touchpad back plate.
    • Gently grasp the edges of the back plate and pull towards you to remove.
  18. Lift the touchpad out of its placeholder.
    • Lift the touchpad out of its placeholder.
结论
6等其他人完成本指南。
Sheldon Chu
于2012年01月24日注册
1,051 信誉积分
创作了3篇指南
团队
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G27
4 名成员
创作了16篇指南
2条评论
Where is STEP 2 1/2? my keyboard dosnt just fall out nice, how do you remove the keyboard?
Support Services - 回复
Yeah I don't know how to remove keyboard. Also once I get to step 14.. What do I do? You tell me how to identify the broken piece but is it replaceable or fixable?
el jay - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 12
总计 9,430
