简介
The Asus Eee PC 900 uses a small solid state drive instead of a lrger hard drive. Use this guide to replace the SSD in the Asus Eee PC 900.
配件
没有特定配件。
Slide the battery's locking tabs from the locked position to unlocked positions.
The right tab is unlocked when a red dot is showing.
The left tab will have to be held in the unlocked position in order to release the battery.
5等其他人完成本指南。
4条评论
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
