跳转到主内容
Asus Eee PC 1215N Top Cover (Touchpad) Replacement
你所需要的
  1. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: 步骤 1 中的图像 1,2 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
    While there is a fairly long list of tools listed here, I was able to complete the entire guide using only a 3/64" flathead mini screwdriver (the kind you get for $0.99). I replaced the stock 500GB 5400RPM drive with the updated 7200RPM slim drive of the same line with no issues. The BIOS picked it up immediately, and I need only reinstall an OS.
    Tolidano - 回复
    Missing step: remove the two screws under the battery, otherwise the keyboard won’t come off
    Andrea Borgia - 回复
  2. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: 步骤 2 中的图像 1,3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: 步骤 2 中的图像 2,3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement, RAM: 步骤 2 中的图像 3,3
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 3 中的图像 1,1
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 4 中的图像 1,2 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Top Cover (Touchpad) Replacement, Top Cover (Touchpad): 步骤 5 中的图像 1,1
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 6 中的图像 1,3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 6 中的图像 2,3 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 6 中的图像 3,3
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
    excellent guide. but be careful - it's very easy to broke narrow plastic clip :(
    Marcin Dudek - 回复
  7. Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 7 中的图像 1,2 Asus Eee PC 1215N Top Cover (Touchpad) Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
结论
Gaetan
于12/26/12注册
9,574 声望
创作了18篇指南
一条评论
Unrelated. My Asus VX-6 recently had the blue USB 3.0 ports stop working. Now the Ethernet connection is intermittent, goes away, come back, over and over again. Are those 3 ports on the right hand side part of the main board or separate boards?
paul poco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 2,699
