跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Turn the power off and turn the netbook upside down. Slide both battery catches together to release the battery.
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Locate the memory compartment. Using a Plastic Opening Tools, remove the screw rubber cover. Remove the screw.
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Use a Plastic Opening Tools near the screw hole to release the cover.
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  4. 基本电子产品工具包
    小工具包。却有无限可能。
    Shop Toolkits
    基本
    电子产品
    工具包
    Shop Toolkits
  5. Remove the screws as necessary.
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Use a Plastic Opening Tools to release the top cover. Start from the left side. Go around on the bottom
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
  7. Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5). Remove the keyboard 4 screws on the bottom. Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
    • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
    • Remove the keyboard 4 screws on the bottom.
    • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
    • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
    • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
    • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
    • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
    • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
    • Now you can remove the keyboard.
  8. Peel off the protective tape at the bottom left corner. Peel off the warranty void at the bottom right corner and remove the screw below. Remove the 6 other screws.
    • Peel off the protective tape at the bottom left corner.
    • Peel off the warranty void at the bottom right corner and remove the screw below.
    • Remove the 6 other screws.
  9. Remove the protector plate. Remove the protector plate.
    • Remove the protector plate.
结论
2等其他人完成本指南。
Gaetan
于2012年12月26日注册
9,487 信誉积分
创作了18篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 12
总计 3,068
