跳转到主内容
加入维修社区 - 创建账户
Asus Eee PC 1201N RAM Replacement
你所需要的
  1. Asus Eee PC 1201N RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N RAM Replacement: 步骤 2 中的图像 1,1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N RAM Replacement: 步骤 3 中的图像 1,1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N RAM Replacement, RAM: 步骤 4 中的图像 1,2 Asus Eee PC 1201N RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    • Then use the plastic opening tool to open the RAM door.
  5. Asus Eee PC 1201N RAM Replacement: 步骤 5 中的图像 1,1
    • Push the tabs on the side of the RAM to release.
    • Only push the tabs over slightly to ensure you do not break them.
  6. Asus Eee PC 1201N RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the RAM by pulling it towards you.
结论
Trae Mikesell
于10/04/16注册
397 声望
创作了3篇指南
团队
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 的会员
USFT-NANCE-F16S2G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,152
