跳转到主内容
Asus Eee PC 1201N Hard Drive Replacement
你所需要的
  1. Asus Eee PC 1201N Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Hard Drive Replacement, Keyboard: 步骤 4 中的图像 1,2 Asus Eee PC 1201N Hard Drive Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Hard Drive Replacement: 步骤 5 中的图像 1,2 Asus Eee PC 1201N Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Turn the netbook over and remove the eight 6.5mm screws using the J0 Phillips head screwdriver.
  7. Asus Eee PC 1201N Hard Drive Replacement: 步骤 7 中的图像 1,2 Asus Eee PC 1201N Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Turn the netbook back over and remove the ten 4.5mm screws using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Flip up the retaining flap on the ZIF connector. Then, pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the four 4.6mm screws with the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Hard Drive Replacement: 步骤 10 中的图像 1,2 Asus Eee PC 1201N Hard Drive Replacement: 步骤 10 中的图像 2,2
    • Slide the hard drive to the right and then lift it straight out of the netbook.
结论
4等其他人完成本指南。
Trae Mikesell
于10/04/16注册
394 声望
创作了3篇指南
团队
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 的会员
USFT-NANCE-F16S2G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 3,360
