跳转到主内容
Asus Eee PC 1201N Cooling fan replacement
你所需要的
  1. Asus Eee PC 1201N Cooling fan replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Cooling fan replacement: 步骤 2 中的图像 1,1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Cooling fan replacement: 步骤 3 中的图像 1,1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Cooling fan replacement, Keyboard: 步骤 4 中的图像 1,2 Asus Eee PC 1201N Cooling fan replacement, Keyboard: 步骤 4 中的图像 2,2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Cooling fan replacement: 步骤 5 中的图像 1,2 Asus Eee PC 1201N Cooling fan replacement: 步骤 5 中的图像 2,2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Cooling fan replacement, Cooling fan: 步骤 6 中的图像 1,1
    • Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
  7. Asus Eee PC 1201N Cooling fan replacement: 步骤 7 中的图像 1,2 Asus Eee PC 1201N Cooling fan replacement: 步骤 7 中的图像 2,2
    • Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Cooling fan replacement: 步骤 8 中的图像 1,1
    • Pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Cooling fan replacement: 步骤 9 中的图像 1,1
    • Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Cooling fan replacement: 步骤 10 中的图像 1,1
    • Unplug the connector.
  11. Asus Eee PC 1201N Cooling fan replacement: 步骤 11 中的图像 1,1
    • Lift up and remove the fan.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 的会员
USFT-NANCE-F16S2G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 951
