跳转到主内容
Asus Eee PC 1015PN motherboard dismantling (English)
你所需要的
  1. Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: 步骤 1 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: 步骤 1 中的图像 2,2
    • To remove the battery, unlock the marked tabs.
  2. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 2 中的图像 1,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 2 中的图像 2,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 2 中的图像 3,3
    • To remove the memory, lift the plastic tab covering the memory screw with a small slot head screwdriver.
  3. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 3 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 3 中的图像 2,2
    • Lift the plastic cover and remove the SO-DIMM module.
  4. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 4 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 4 中的图像 2,2
    • Remove the dummy SD-Card
  5. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 5 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 5 中的图像 2,2
    • Unscrew 4 screws that are located in the battery compartment. Once removed, plastic tabs need to be removed on the upper part.
  6. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 6 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 6 中的图像 2,2
    • With an extraction tool, separate the keyboard chassis from the netbook, it has many tabs.
  7. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 7 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 7 中的图像 2,2
    • While separating the keyboard chassis, be careful with the keyboard connector. To remove it, simply slide the plastic retainer to be able to free it.
  8. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 8 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 8 中的图像 2,2
    • Unscrew the marked screws. One of those screws is behind a warranty sticker.
  9. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 9 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 9 中的图像 2,2
    • Disconnect the mouse connector. The connector has a white plastic tab that disconnects the connector.
  10. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 10 中的图像 1,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 10 中的图像 2,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 10 中的图像 3,3
    • With a flat screwdriver, release two plastic tabs ( 1 on each side), and with pressure in the front, release the chassis.
  11. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 11 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 11 中的图像 2,2
    • To disconnect the hard drive, two connectors need to be removed, pay attention to the connectors sides, the one on the left in marked as MB and the right is marked as IO.
  12. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 12 中的图像 1,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 12 中的图像 2,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 12 中的图像 3,3
    • Remove the screws, and slide the hard drive free.
  13. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 13 中的图像 1,1
    • Disconnect the motherboard connector and the IO plate.
  14. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 14 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 14 中的图像 2,2
    • Remove the fan connector, the BIOS battery and the upper connector.
  15. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 15 中的图像 1,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 15 中的图像 2,3 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 15 中的图像 3,3
    • Remove the plate screws and release the screen connector.
  16. Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 16 中的图像 1,2 Asus Eee PC 1015PN  motherboard dismantling (English): 步骤 16 中的图像 2,2
    • Remove the motherboard from the chassis, and disconnect a connector that is glued.
结论
6等其他人完成本指南。
由衷感谢以下译者:
es en
100%
DeZom正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
Joder la que hay que liar para cambiar el disco duro.
Rafael Belmonte - 回复
Thank you for the guide
ilcaccillo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 13,802
