跳转到主内容
Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement
你所需要的
  1. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement, Trackpad Mouse Clicker (the button's on the bottom of the trackpad): 步骤 1 中的图像 1,1
    • Use an opening too to carefully separate the palm rest assembly from the base of the laptop.
    • Move the opening tool around the perimeter of the palm rest and the base and use it as a wedge.
    • You will need to undo the clips holding the two parts together with the opening tool. Be careful not to break the clips.
  2. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: 步骤 2 中的图像 1,2 Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a spudger to open the cable locks and remove the ribbon cables using your hands or tweezers.
    • Using a Phillips #00 screwdriver, remove the two 4 mm screws on either side of the circuit board.
结论
另外一个人完成了本指南。
Michael Dooley
于04/18/13注册
138 声望
创作了3篇指南
团队
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G52
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,015
