当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Lift the side of the keyboard.
Disconnect the attached ribbon located underneath the keyboard.
Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
Carefully pull the circuit board away from side of device base.
Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
Gently lift the screen portion from the base.
Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
Use your fingers to hold the screen and carefully lift it from the base.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
