跳转到主内容
Asus Eee PC 1008ha Graphics Card Replacement
你所需要的
  1. Asus Eee PC 1008ha Graphics Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Graphics Card Replacement: 步骤 2 中的图像 1,3 Asus Eee PC 1008ha Graphics Card Replacement: 步骤 2 中的图像 2,3 Asus Eee PC 1008ha Graphics Card Replacement: 步骤 2 中的图像 3,3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Graphics Card Replacement: 步骤 3 中的图像 1,2 Asus Eee PC 1008ha Graphics Card Replacement: 步骤 3 中的图像 2,2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Graphics Card Replacement, Graphics Card: 步骤 4 中的图像 1,1
    • Remove the two 2mm screws from the graphics card.
  5. Asus Eee PC 1008ha Graphics Card Replacement: 步骤 5 中的图像 1,3 Asus Eee PC 1008ha Graphics Card Replacement: 步骤 5 中的图像 2,3 Asus Eee PC 1008ha Graphics Card Replacement: 步骤 5 中的图像 3,3
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
结论
另外一个人完成了本指南。
Alex Powers
于04/17/13注册
101 声望
创作了2篇指南
团队
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G52
4 名成员
创作了11篇指南
一条评论
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 20
总计 3,619
