简介
The wifi card is located under the trackpad of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in.
Warning: This guide causes warranty of laptop to be voided.
  1. Start by placing the laptop upside-down on a flat surface.
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position. While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Using both hands, pull the battery horizontally away from the laptop.
    • Using both hands, pull the battery horizontally away from the laptop.
  5. Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
    • Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
  6. Using the wide opening tool, unhook each clip from its original position by pulling the clip towards you. Repeat for all four of the clips. Repeat for all four of the clips.
    • Using the wide opening tool, unhook each clip from its original position by pulling the clip towards you.
    • Repeat for all four of the clips.
  7. Turn the laptop right side up and lift the lid.
    • Turn the laptop right side up and lift the lid.
    • Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
    • Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
    • Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
  8. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  9. The keyboard should now lift from the base of the laptop.
    • The keyboard should now lift from the base of the laptop.
    • Do not lift the keyboard up to quickly or too hard, since a ribbon cable is still attached to the keyboard and doing so could break it.
  10. Using the pointed end of the spudger tool, disconnect the ribbon cable that extends from the bottom of the keyboard to the computer by pushing on the connections of the cable. Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop. Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop.
    • Using the pointed end of the spudger tool, disconnect the ribbon cable that extends from the bottom of the keyboard to the computer by pushing on the connections of the cable.
    • Once the ribbon cable is disconnected, the keyboard can be fully removed by lifting it away from the laptop.
  11. Turn laptop upside down. Find and unscrew the 5.5 mm Phillips #1 screw on the ram cover.
    • Turn laptop upside down.
    • Find and unscrew the 5.5 mm Phillips #1 screw on the ram cover.
    • The screw and ram cover are connected and will not separate.
  12. Carefully remove the cover by lifting it with your fingers. Make sure that you do not pull the cover too hard because there are plastic pins that hold the cover on.
    • Carefully remove the cover by lifting it with your fingers.
    • Make sure that you do not pull the cover too hard because there are plastic pins that hold the cover on.
  13. Locate and remove the silver 6.65 mm Phillips #1 screw in the bottom right corner of the opening. Locate and remove the silver 6.65 mm Phillips #1 screw in the bottom right corner of the opening.
    • Locate and remove the silver 6.65 mm Phillips #1 screw in the bottom right corner of the opening.
  14. Remove the four 6 mm screws with the Phillips #1 screwdriver.
    • Remove the four 6 mm screws with the Phillips #1 screwdriver.
  15. Release the 3 black clips by pushing them in with the pointed end of the spludger. Release the 3 black clips by pushing them in with the pointed end of the spludger. Release the 3 black clips by pushing them in with the pointed end of the spludger.
    • Release the 3 black clips by pushing them in with the pointed end of the spludger.
  16. This step will void the warranty
    • This step will void the warranty
    • Remove the all five 5.5 mm Phillips #1 screws.
  17. Remove the ribbon cable that is connected to the circuit board with the pointed end of the spudger.
    • Remove the ribbon cable that is connected to the circuit board with the pointed end of the spudger.
  18. Pry up the plastic frame at the top corners. Use the wide end of spudger and slide it between the bottom case and the plastic red to release it. The red plastic frame and the silver piece of metal are connected and will come off together.
    • Pry up the plastic frame at the top corners.
    • Use the wide end of spudger and slide it between the bottom case and the plastic red to release it.
    • The red plastic frame and the silver piece of metal are connected and will come off together.
  19. Fold back the ribbon cable away from you. Remove the 3.6 mm Phillip #1 screw.
    • Fold back the ribbon cable away from you.
    • Remove the 3.6 mm Phillip #1 screw.
  20. Fold the ribbon cable the opposite way and lift up the wifi card.
    • Fold the ribbon cable the opposite way and lift up the wifi card.
  21. Remove the Wi-Fi card by pulling the card away from where it was plugged in. Don't pull the wifi card out too fast because the antenna is still attached and doing so could damage the antenna or connector.
    • Remove the Wi-Fi card by pulling the card away from where it was plugged in.
    • Don't pull the wifi card out too fast because the antenna is still attached and doing so could damage the antenna or connector.
  22. Pull the antenna away from the wifi card to remove it. Pull the antenna away from the wifi card to remove it.
    • Pull the antenna away from the wifi card to remove it.
结论
4等其他人完成本指南。
Aaron Arenas
于2014年04月20日注册
667 信誉积分
创作了5篇指南
团队
Cal Poly, Team 13-32, Maness Spring 2014 Cal Poly, Team 13-32, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G32
5 名成员
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 1,242
