跳转到主内容
Asus Eee PC 1005PEB RAM Replacement
你所需要的
  1. Asus Eee PC 1005PEB RAM Replacement, RAM: 步骤 1 中的图像 1,2 Asus Eee PC 1005PEB RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Start by having the laptop upside down on a hard flat surface.
    • Find and unscrew the 6.65 mm Phillips #1 screw.
    • The screw will not detach from the RAM cover.
  2. Asus Eee PC 1005PEB RAM Replacement: 步骤 2 中的图像 1,2 Asus Eee PC 1005PEB RAM Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the cover by lifting it with your fingers.
    • Make sure that you do not pull the cover to quickly or too hard as this could damage the plastic pins that hold the cover on.
  3. Asus Eee PC 1005PEB RAM Replacement: 步骤 3 中的图像 1,2 Asus Eee PC 1005PEB RAM Replacement: 步骤 3 中的图像 2,2
    • Identify the pins on both sides of the RAM.
    • Using both hands, pull the pins apart from each other to release the RAM.
    • The RAM will "pop" up on its own after the pins are pressed.
  4. Asus Eee PC 1005PEB RAM Replacement: 步骤 4 中的图像 1,1
    • Grab the RAM stick with two fingers and gently pull it out of its slot.
结论
另外一个人完成了本指南。
Aaron Arenas
于04/20/14注册
751 声望
创作了5篇指南
团队
Cal Poly, Team 13-32, Maness Spring 2014 Cal Poly, Team 13-32, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G32
5 名成员
创作了5篇指南
一条评论
Everything I've read says you can only upgrade from the 1gb ram to a 2gig. Here's what I just installed: http://amzn.to/2x0flty and so far its working great...I notice a difference in speed, although this thing is still slow.
Dan Fowler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 926
