跳转到主内容
Asus Eee PC 1005PEB Battery Replacement
  1. Asus Eee PC 1005PEB Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Asus Eee PC 1005PEB Battery Replacement: 步骤 2 中的图像 1,1
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Asus Eee PC 1005PEB Battery Replacement: 步骤 3 中的图像 1,2 Asus Eee PC 1005PEB Battery Replacement: 步骤 3 中的图像 2,2
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Asus Eee PC 1005PEB Battery Replacement: 步骤 4 中的图像 1,1
    • Using both hands, pull the battery horizontally away from the laptop.
结论
2等其他人完成本指南。
Aaron Arenas
于04/20/14注册
751 声望
创作了5篇指南
团队
Cal Poly, Team 13-32, Maness Spring 2014 Cal Poly, Team 13-32, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G32
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,548
