跳转到主内容
Asus Eee PC 1005HA Screen Replacement
你所需要的
  1. Asus Eee PC 1005HA Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Screen Replacement: 步骤 2 中的图像 1,3 Asus Eee PC 1005HA Screen Replacement: 步骤 2 中的图像 2,3 Asus Eee PC 1005HA Screen Replacement: 步骤 2 中的图像 3,3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Screen Replacement, Screen: 步骤 3 中的图像 1,3 Asus Eee PC 1005HA Screen Replacement, Screen: 步骤 3 中的图像 2,3 Asus Eee PC 1005HA Screen Replacement, Screen: 步骤 3 中的图像 3,3
    • Using tweezers, remove the six screw covers on the screen bezel.
    • Remove the six 4.6 mm screws from the bezel.
  4. Asus Eee PC 1005HA Screen Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
    • Carefully remove the bezel from the display.
  5. Asus Eee PC 1005HA Screen Replacement: 步骤 5 中的图像 1,3 Asus Eee PC 1005HA Screen Replacement: 步骤 5 中的图像 2,3 Asus Eee PC 1005HA Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the four 3.6 mm screws securing the screen.
    • Slowly lift the screen up from the rest of the laptop.
    • The screen is still attached to the laptop by a set of cables. Be careful not to damage them while removing the screen.
  6. Asus Eee PC 1005HA Screen Replacement: 步骤 6 中的图像 1,2 Asus Eee PC 1005HA Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the plastic tape securing the display cables to the back of the screen.
    • Slide the display cable connector out its socket on the back of the screen.
  7. Asus Eee PC 1005HA Screen Replacement: 步骤 7 中的图像 1,2 Asus Eee PC 1005HA Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the four 3.1 mm housing screws on the sides of the display housing frame
    • Remove the housing frame.
结论
13等其他人完成本指南。
Mitchell Cesare
于01/31/12注册
784 声望
创作了4篇指南
团队
Cal Poly, Team 11-22, Maness Winter 2012 Cal Poly, Team 11-22, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G22
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 22
总计 21,235
